82 camaro - Team Camaro Tech
post #1 of 3 (permalink) Old May 31st, 01, 10:47 AM Thread Starter
Thumbs down
i resently swapped out my old cross fire 350 to a tpi 350, done with a wiring harness from PAINLESS WIRING. the dam thing won't start unless i spray fuel in the intake first. runs great after. any suggestions
tuckstoy is offline
post #2 of 3 (permalink) Old May 31st, 01, 11:28 AM
ZZ_430's Avatar
Does it have fuel pressure when cranking?
zz430droptop67rs
67 RS/SS Convertible, 70 RS/Z28 or Pro-Touring.com My Page
ZZ_430 is offline
post #3 of 3 (permalink) Old May 31st, 01, 08:05 PM
Did you replace the fuel pump with a higher psi pump? To build presure immediately when you turn your ignition switch.Is it a electic pump or mechanical one?
Rusty is offline
