what plugs HELP - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 21st, 02, 02:47 PM Thread Starter
i HAVE A SET OF bbc HEADS THAT i AM PUTTING ON A 402 THEY ARE PART #353049 MADE IN 1972
i AM TRYING TO USE R44T plugs but there seems to be blow by around the threads to plug hole are these correct also what are thse heads off of just for grins
454bruce is offline
post #2 of 4 (permalink) Old Oct 22nd, 02, 01:32 AM
I came up with 73'-84 on a 454 open chambered ,122 cc chamber. Sorry no application.
You should be using a plug with the TS suffix, as in tapered seat, then it should seal with no problems.
Drew
drew69 is offline
post #3 of 4 (permalink) Old Oct 22nd, 02, 11:22 AM
First of all, you need to check to see whether or not your heads are for tapered seat plugs. If you have tapered seat plugs where you really need gasketed, that could cause your leak. My books don't tell me which seat those heads are machined for.
Secondly, the TS does not stand for tapered seat. The "T" is for tapered seat, the "S" is for extended tip.
kurt6325 is offline
post #4 of 4 (permalink) Old Oct 22nd, 02, 12:25 PM
Kurt is right T is for tapered and the S is for extended reach. The tapered seat plugs started appearing around 71'. I haven't used AC Delco spark plugs in a while.
Check the seats on your head as Kurt suggested, a tapered counterbore will be easily seen at the spark plug hole.
drew69 is offline
