Fans wont come on - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 10th, 02, 02:00 PM Thread Starter
I have a 96 Camaro and the fans wont come on unless I have the A/C on. I have new relays, new ECM, new temp. switches, new thermo., and plenty of fluid in the radiator. I can turn the fans on with a diagnostic scanner but that's it. Any suggestions? (the thermostat works cause it runs at 165 going down the road)
Ay96SS is offline
post #2 of 5 (permalink) Old Jun 10th, 02, 02:28 PM
ZZ_430's Avatar
How hot is it getting?
220 degrees or so is when the fans are supposed to come on.
Don~ ZZ430DropTop
~~~~and~~~~
70 RS/Z28
67 RS/SS Convertible, 70 RS/Z28
ZZ_430 is offline
post #3 of 5 (permalink) Old Jun 10th, 02, 03:30 PM Thread Starter
I let it get all the way up to 242*. I can turn the fans on with a diagnostic scanner. But they wont come on when they are supposed to.
Ay96SS is offline
post #4 of 5 (permalink) Old Jun 10th, 02, 03:49 PM
ZZ_430's Avatar
Have you checked all the ECM grounds?
Don~ ZZ430DropTop
~~~~and~~~~
70 RS/Z28
ZZ_430 is offline
post #5 of 5 (permalink) Old Jun 10th, 02, 07:19 PM Thread Starter
No, I haven't. Can you tell me where they are located at? It started acting up after I jacked the motor up to put in a High Volume Oil pump. I might have pulled a wire loose.
Ay96SS is offline
