Carb Drip - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 16th, 03, 03:35 PM Thread Starter
After rebuilding my BG sports claw 750 dp the primary emptys slowly.
The drip is from around the primary butterfly blade shaft. Is that a good description ? Its where the throttle linkage connects to the carb.
So after about 8 hours the primary bowl is low enough I cant shake the car hard enough to see fuel.
I have replaced the bowl and metering block gasket twice since the rebuild trying to fix this leak.
Did I miss something during the rebuild ?
My Camaro
impzilla is offline
post #2 of 4 (permalink) Old Apr 17th, 03, 06:23 PM
I'll take a stab at this since no one's touched it yet.
Make sure the fuel's not coming from the primary accelerator pump located under the front fuel bowl. The diaphragms in these often go bad. There's a slim chance the fuel is following the linkage. Most of the time they just leave a puddle on the intake. If the fuel bowl and metering plate are ok that's the only thing I can think of.
'69 RS Camaro 355 5-speed 4.11
1 2RUN is offline
post #3 of 4 (permalink) Old Apr 18th, 03, 12:51 AM
Cool
I'll also take a chance, wonder what the prize is?
It might be a cracked carb body due to the bottom bowl screw hole may have had some foreign (as opposed to domestic) material in the threads and when the screw was installed, it may have bottomed out and kept pushing. Thereby creating a minute crack and the fuel is following the threads and seeping through.
You can always empty out the salt shaker from the kitchen table and fill it with flour. Go out to carb and sprinkle flour all around. Find the dampness and there's your leak.
Another thing you might do is to apply 2-3 psi of shop air to the bowl vent. Look for leaks. If you have a carb with a fuel transfer tube for both bowls, then you will need to "Y" the vents together and pressurize both bowls together.
post #4 of 4 (permalink) Old Apr 18th, 03, 03:20 AM Thread Starter
I have watched the leak for a few days now and the leak is from the throttle shaft.
Nothing under the pump.
I didnt think fuel was at that part of the carb.
Could the venturis leak and the fuel work its way out through the shaft ?
My Camaro
impzilla is offline
