Trunk won't open - Team Camaro Tech
post #1 of 11 (permalink) Old Apr 29th, 01, 01:11 PM Thread Starter
I have a few problems with my '85 Camaro Z/28. One thing is when I push the trunk switch inside the car it won't unlatch the trunk. I can't figure out why. Another is on the dual power mirrors. When I try to ajust them on the switch not one well move like its not getting any power. Same thing with the power doors. They won't lock or unlock with the switch.
Ryan
Thym is offline
post #2 of 11 (permalink) Old Apr 29th, 01, 02:23 PM
Check your fuses....I'd be willing to bet that all of these accessories run off the same fuse.
Justin Traunero
[email protected]
-1967 Camaro SS350
http://156.143.134.136/default.htm
jrt67ss350 is offline
post #3 of 11 (permalink) Old Apr 29th, 01, 03:37 PM Thread Starter
All the fuses are alright. I replaced all of them a couple days ago hoping it would fix it but it didn't. And thank you Justin.
Thym is offline
post #4 of 11 (permalink) Old Apr 29th, 01, 07:44 PM
Dale
All thoes things run off the courtesy fuse (orange wire)Does the dome light work,how about the horn?
68 z28 ,68 rs 327 ,73 454 vette, 2 goofy kids
dale68z is offline
post #5 of 11 (permalink) Old Apr 30th, 01, 05:07 AM Thread Starter
The dome light does not work either. Is it the one with an orange and white wires going into a circular plugin thingy?
Ryan
Thym is offline
post #6 of 11 (permalink) Old Apr 30th, 01, 05:28 AM
Cool
Wiggle and/or push shift level in Park or Neutral. Electric trunk won't work if not in one of these positions.
post #7 of 11 (permalink) Old Apr 30th, 01, 10:00 AM
Your gas lifts on your trunk are probably just worn out if all your electrical is fine. Those glass hatches are pretty heavy. If this is the problem your hatch will only stay open when it's in the full up position, it will shut on it's own from the weight if only half way open.
[This message has been edited by Sparky3 (edited 04-30-2001).]
Sparky3 is offline
post #8 of 11 (permalink) Old Apr 30th, 01, 07:34 PM
Dale
The dome light ,typically has a org. and white wire.The dome light is also on the same fuse as the hatch,horn,cig. lighter,trunk release.Does any of these things work?
dale68z is offline
post #9 of 11 (permalink) Old May 1st, 01, 12:16 PM Thread Starter
dale68z none of them work. Which fuse it?
Ryan
Thym is offline
post #10 of 11 (permalink) Old May 1st, 01, 07:10 PM
Dale
It's a 20 amp.(ctsy) fuse,next to the circuit breakers(silver metal things)
dale68z is offline
post #11 of 11 (permalink) Old May 2nd, 01, 07:37 AM
That's what happened to my 84. Still can't figure it out. I took the whole console apart, checked connections and still nothing. The realy strange part was that at the same time, my car wouldn't start either. Turn the key, and nothing, I would get a power drain as if it was turning over, but nothing would hapen. I have since had to make a seperate ignition button that only works with the key in. Consiquently, my reverse lights went out too. Bulbs, fuses checked okay...??
Bitchin' camaro is offline
