sqweeky - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 4th, 03, 05:19 AM Thread Starter
robert
rolling-robert's Avatar
hi,
my 305 chevy v8 carbed from 1984 has a skweeky sound while idling, is it the waterpump, ventilator,altenator or that a/c thing?
what can i do about it? it is pretty annoying.
thanx
Z28 1984
'77 355ci/COMP cam 218/224 .464/.470 114 LSA
rollerrockers1.5/9.72 forged pistons
ported '66 461 heads 1.94,1.5/Flowtech shorty headers
edelbrock 600/performer rpm intake
th350/shiftkit/hughes2500stall
4th gen 3.23 10 bolt POSI.
rolling-robert is offline
post #2 of 4 (permalink) Old Apr 4th, 03, 05:45 AM
J
It could just be a loose belt. Check to make sure they are all tighten properly.
You can see if its a pully by spraying a little lubricant one at a time and see when the squeak goes away.
magisnyc is offline
post #3 of 4 (permalink) Old Apr 4th, 03, 08:12 AM
To determine if its a belt or pulley, take off the belts and fire it up <not for long though>and if you still have the squeek could be a main bearing?
68 Camaro~LSx ~all motor
post #4 of 4 (permalink) Old Apr 4th, 03, 05:20 PM
Without ramming a hole thru your head get a wooden rod like 1/4" or so and put it to parts and your ear. The sound/vibration goes right up the shaft. Put your ear near the end of it and you'll know where the sound is loudest. But definately don't put it right up to the opening of your ear area. That would be when the engine misses and torques the rod thru your head. Murphy was right. Don't forget to check next to the valve covers to eliminate that area.
Snatchin'gears is offline
