67 4 speed transmission stuck in reverse - Team Camaro Tech
post #1 of 7 (permalink) Old Oct 27th, 03, 05:28 AM Thread Starter
I have a curious problem. Backed the car into the garage and now it won't come out of reverse.
There has been no indication of any noise from the Muncie 4 Speed.
The shifter seems to be in neutral, but it is still in reverse. I can move the shifter into 1,2,3,4, but car is still in reverse.
I can't put the shifter into reverse.
I don't see anything bent or broken from the underside.
Any ideas?
67ss/rs is offline
post #2 of 7 (permalink) Old Oct 28th, 03, 03:18 AM
a67
Using a mallet or block of wood knock the linkage back to the neutral gate position. Then double check the shift linkage adjustment. It may be off, or it may be worn which leaves the trans in reverse.
Bob.
a67 is offline
post #3 of 7 (permalink) Old Nov 1st, 03, 06:03 PM
To see if it's trans or linkage you know the simple route right?
By yourself put the shifter in neutral. Look under car at left side of tranny where linkages attach and see if both flat bars are straight up and down.
If you have somebody else have them shift while you watch. Straight up and down is neutral. Only one flatbar should move at a time.
To get the linkage right disconnect it where the threaded portion is at the shifter then find neutral and put a drill bit, allen wrench or whatevers thru a hole in the shifter gate shafts that will lock the shifter in neutral. Then adjust till each linkage goes back on the easiest of all.
You can get an idea here. Oh yah, in reverse. Maybe binding. Check the linkage. Compair attachments. Straight up and down is neutral.
http://www.mrgasket.com/hurstpdf/3734531.pdf
http://www.mrgasket.com/hurstcomp.html
Snatchin'gears is offline
post #4 of 7 (permalink) Old Nov 3rd, 03, 06:43 AM Thread Starter
Thanks for the input. I didn't know of the "simple route". I will take a look at it this evening.
67ss/rs is offline
post #5 of 7 (permalink) Old Nov 4th, 03, 08:23 AM Thread Starter
Well, things now work [img]smile.gif[/img]
Just put the clutch in and pushed the car out of the garage. I let out the clutch to stop the car. The shifter then moved and could go into any gear.
Don't know what happened, but would be interested in finding out what actually when "wrong".
67ss/rs is offline
post #6 of 7 (permalink) Old Jan 6th, 04, 11:35 AM
Art
Send a message via Skype™ to Guido67SS
It's probably the shifter linkage. You can tighten it up by using washers as spacers behind the clips that hold the rods to the shifter and the shift forks. Metal bushigs can also be used. The stronger you make the linkage, less slop the better it will feel.
I know that when I raced my 4 speed I had my shifter set just right. Never wanted to miss a gear on a power shift you know!
I miss that...
67 Camaro Built with Cubic Money
Guido67SS is offline
post #7 of 7 (permalink) Old Jan 7th, 04, 12:25 AM
Johnny
Cool
Be sure to set the parking brake so that the car won't run over you when you get the transmission back in neutral & it wouldn't be a bad ideal to place a block of wood in front & the back of the rear tires. Safety first.
johnnyr is offline
