Hot Start Problem - Team Camaro Tech
post #1 of 2 (permalink) Old Apr 16th, 01, 08:07 AM Thread Starter
I have a 1985 Camaro Berlinetta with a 2.8 v-6. The in-tank electric fuel pump was replaced a few months ago by a GM dealership. Ever since I have noticed the car has to crank several times before it starts when hot after sitting for a while. The car starts right away when cold or if it has only been sitting for a few minutes hot. If the car sits for half an hour or more, it takes serveral cranks to start the engine. If I leave the car sitting overnight after driving it all day, it starts right away in the morning. I have read a lot of messages talking about a check valve in the fuel pump being the problem. Is there a check valve in this fuel pump?
Any ideas what the problem may be?
Thanks,
Greg
[This message has been edited by GregHipkin (edited 04-16-2001).]
GregHipkin is offline
post #2 of 2 (permalink) Old Apr 16th, 01, 06:35 PM
Sometimes the fuel injectors will bleed down the pressure from the line if they are leaking. Then you have to crank it until the fuel builds pressure back up
I had a 454 that did that when I worked at a shop.
It rattled my brain for a few hours and another mecanic told me to try replacing the injectors .
Well it worked.
Just a thought if nothing else works.
6-71BlownCamaro is offline
