Missed Shift - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 11th, 01, 02:50 AM Thread Starter
Lets just say it spun up a bit. I am going to GUESS well into the 7k range. This is a fairly tame motor with a Comp 262. Oil, temp and noise all seems fine, but what, if any, can I look for in case a problem developes? This motor has about 1500 miles on it, so I really am hopeful the HEI did its job and gave crappy spark upstairs!
1992 Firebird 355/Six Speed
1991 RS 350 / 700-R4
1987 Toyota Pickup 383 / 500 + HP 10.79 @ 123.95 Slicks / 11.997 @ 114.23 Radials
"Speed KILLS, so drive a FORD and live forever!"
http://personal.lig.bellsouth.net/~racer383/
Member of the "unwanted" 3rd Gen group.
Mark W. Winning is offline
post #2 of 5 (permalink) Old Jun 11th, 01, 02:27 PM
I think that you should be ok. The only problem that I can see you having is with the piston skirts, if you used cast pistons. I have gone thru this. They can collapse. But, if you don't hear them slapping you should be ok. Good luck.
NOMANRS is offline
post #3 of 5 (permalink) Old Jun 12th, 01, 02:09 AM
Rick
A rev limiter is cheap insurance, too.
Rick Dorion
69 RS Conv,355,M20,4:10
RickD is offline
post #4 of 5 (permalink) Old Jun 12th, 01, 02:52 AM Thread Starter
The pistons I used don't have skirts. They were the common ones from Speed Pro. Maybe thats a good thing! Two days later and everything seems cool.
The worst part is my MSD 6AL is mounted in the engine compartment. My Comp 9000 is sitting in my back seat. I have just been to lazy to hook it up. Guess what. I wired everything yesterday. Tonight I will drop the 9000 in and be safe. Normally I am the one that preaches the cheap insurance of a rev limiter!
Thanks for you responces guys, I feel better now.
post #5 of 5 (permalink) Old Jun 12th, 01, 06:48 AM
It should be fine usually the valve gear takes a beating from valve float {mother natures rev limiter} but I don't think 7000 should hurt you. You might check the compression just to make sure a valve didn't kiss a piston and bend it.
oger is offline
