Temp sending unit not working - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 23rd, 02, 08:04 PM Thread Starter
I bought a new sending unit for my idiot light but the temp light's still not coming on with the ignition on or any other time. A manual told me to remove the wire and ground it, then the light should come on, which it does. I don't get it. Would love some help with this (yes I know I need a gauge!).
nantuckett 67 is offline
post #2 of 3 (permalink) Old Aug 24th, 02, 03:33 AM
Make sure you don't use teflon tape or anything else that would insulate the switch from ground. The switch is nothing but a contact the closes when the engine temperature gets above the setpoint. Make sure you didn't get a sender for use with a temperature gauge. Stick on ohmmeter on the center terminal of the switch and make sure you have infinite resistance (open circuit)
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
My 69 L48 - 350/300HP Engine
Mark C is offline
post #3 of 3 (permalink) Old Aug 24th, 02, 07:48 PM Thread Starter
ok, I'll try that...thanks very much.
