Edelbrock problem... - Team Camaro Tech
post #1 of 4 (permalink) Old Feb 2nd, 03, 11:53 AM Thread Starter
My car has been sitting for about six months...it was pretty today so I went to start it and it ran TERRIBLE...wouldn't idle,gas smell,smoking,gas leaking out the carb...do I have a stuck float?the carb is practically brand new-do I have to disassemble it to fix it?I don't have good luck with that-it'll leak from now on!I changed the plugs because they were gas fouled(I think)any and all advice will be greatly appreciated-thanks!
coley is offline
post #2 of 4 (permalink) Old Feb 2nd, 03, 03:12 PM
An old trick we used to use with quardrajets was to blow in the bowl vent tube with compressed air at low pressure. Just a psstt was about all it took and would clear the idle bleed jets, kerchunk the power valve, and jar the float. I think the edelbrock carbs are q-jet design aren't they?
Anyway, if you manage to get the floats free, a can a gas treatment might be good to disolve some of the goo.
-dnult
[This message has been edited by dnult (edited 02-02-2003).]
dnult is offline
post #3 of 4 (permalink) Old Feb 2nd, 03, 03:24 PM Thread Starter
Is the Edelbrock the same as the Q-Jet?It looks like the old Carter(exterior anyway)...anyway,will that work?Worth a try,I guess...thanks!
[This message has been edited by coley (edited 02-02-2003).]
coley is offline
post #4 of 4 (permalink) Old Feb 2nd, 03, 06:06 PM
David Pozzi
davidpozzi's Avatar
Are you sure the choke didn't stick closed?
David's Motorsports page
First Gen Suspension Page
davidpozzi is offline
