Bad clutch? Slave Cylinder? help - Team Camaro Tech
post #1 of 2 (permalink) Old Nov 27th, 01, 03:10 AM Thread Starter
Would be thankful for any advice.... Built an 84 Camaro Z28. Came with Borg Warner t 5 speed. We put a 69 327 in. The other day my we were in the driveway the clutch pedal just went to nothing and cut the car off. Was not hossing it just idling.Does this sound like the clutch went out Or the Slave cylinder went out.If you mash the pedal THE rubber piece on the cylinder moves a little.Thanks for any help.
junkfarmer is offline
post #2 of 2 (permalink) Old Nov 27th, 01, 11:50 AM
Joe
If theres no fliud loss than I would suspect the clutch master cylinder. If you have fliud loss than you need to find where it is leaking from.
70 camaro 307 (350soon) /350th
Joekool1234567 is offline
