Timing help - Team Camaro Tech
post #1 of 2 (permalink) Old Sep 28th, 02, 03:57 AM Thread Starter
I have a 69 SS w/350 (not original). I was tuning it up the other day and can't figure out the timing. Initial timing at idle w/o vac. advance was 6-8 BTDC-it ran terrible. I advance it to about 16 BTDC and now it runs much better. I could hear it improve as I moved the distributor. But there's too much advance; when I let off on the throttle @ 15-40 MPH it wants to "jump" or erratically misfire-Feels like too much advance. It even did this some at 6-8 BTDC. Can the balancer be put on wrong so the degree readings are wrong? The tune up book says 0 BTDC. What gives? Am I out in left field? Thanks for the help!
Rookobird is offline
post #2 of 2 (permalink) Old Sep 29th, 02, 04:21 AM
John, the balancer can only go on one way to answer your question.
I have seen balancers spin on the rubber which would through the timing marks off but that isn't very common.
Depending on the year you could have the wrong timing pointer on the engine. Older engines were located at about 3 o clock looking from the front while newer engines are located 12 to 1 o clock which is visible from behind the waterpump looking down.
You could pull #1 spark plug and get the engine up to the compression stroke, verify piston is at TDC with a piece of wire. You can also remove the valve cover and verify both valves are closed on #1 cylinder but this step shouldn't be necessary. Pull off the distributor cap and verify it is pointing at #1 cylinder & #1 wire on your cap. Then look at the balancer and see where the 0 degree mark is. It should be at TDC on the timing pointer. If it's way off you have the wrong timing tab or the balancer has spun.
Take a piece of white chaulk and draw a straight line across the front of the balancer. If it is spinning in the rubber the line will seperate (move) as you start and stop the engine.
Have you ever checked the engine #'s to find out what year/model it came from? You can do a search on the Tag Team and find out where to decode the engine #'s.
Hope this helps. Keep us posted what you find.
Drew
drew69 is offline
