Sluggish on take off and clicking sound - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 27th, 01, 02:33 PM Thread Starter
Talking
I have a '96 V6 Camaro. Lately, when I start the car and also when accelerating, I hear a clicking sound. It also has a problem when picking up speed. It takes off, chokes a little, and takes off again. It use to have a speedy smooth take off. Do you think this could be due to dirty or broken fuel injectors?
Lori Johnson
Hillsie is offline
post #2 of 6 (permalink) Old Feb 28th, 01, 04:45 AM
Could be a batch of bad gas...lots of problems with water in fuel around this time of year...and the clicking could possible be detonation. Try running the tank down near empty and putting a fresh tank of gas in and see if that helps...you may want to add some water remover (like heet) at the same time. Just a thought.
375hp 78 Chevy truck
77 Chevy Nova
95 Chevy Lumina 3.4L
and building a 78 Nova
travis is offline
post #3 of 6 (permalink) Old Feb 28th, 01, 09:01 AM
Its that blind guy you hit! He is tapping your floor pan with his cane!
Mark W. Winning is offline
post #4 of 6 (permalink) Old Feb 28th, 01, 07:03 PM
Dale
Check your plug wires,sounds like one fell off,or is bad.Do this in the dark,a bad one will be easy to see.Or--- you can just feel around the wires,when you feel the shock,thats the one. Good luck
68 z28 ,68 rs 327 ,73 454 vette, 2 goofy kids
dale68z is offline
post #5 of 6 (permalink) Old Mar 2nd, 01, 01:05 PM
<BLOCKQUOTE>quote:</font><HR>Originally posted by Hillsie:
Lori Johnson
<HR></BLOCKQUOTE>
I have a 1968 327 and I had a bad clicking sound from my engine too. I later found out it was and exhaust leak, it is probably a blown gasket. It could also be a bent push rod. Sorry, I can't help with the take off problem.
I. Larsen
68Camaro327 is offline
post #6 of 6 (permalink) Old Mar 4th, 01, 02:26 PM
could also be a busted valve spring, I had one of those and it made some strange noises and hurt my pickup a bit to say the least.
boodlefoof is offline
