SKIPPING WHEN CAR GET WARM - Team Camaro Tech
post #1 of 6 (permalink) Old Oct 27th, 01, 05:52 PM Thread Starter
Angry
I have a 1997 RS 3.8 and when the car worms up if you floor it it skips. What could be causing it to skip. It like jerks back and forth. It's a 5-speed if that makes any differents.
97/RS is offline
post #2 of 6 (permalink) Old Oct 28th, 01, 03:54 PM
Sounds like you mean it's missing?Sounds like ignition.Check the basics first like sparkplugs and wires.
sschevyfan is offline
post #3 of 6 (permalink) Old Oct 29th, 01, 01:07 PM Thread Starter
all the plugs and wires are new.
97/RS is offline
post #4 of 6 (permalink) Old Oct 30th, 01, 04:45 AM
When you say 'new' does that mean you changed them because of that problem or did it start after that? I believe the 3.8 has no distributor just coils.I have seen these coils crack causing them to spark to ground under a load although on vehicles that were older than 97 but it's worth pulling them off and carefully looking them over.Get a digital multimeter and ohms test all coils and look for differences between them.With out actually 'hearing' what your car is doing and just going off your description I still think it sounds ignition related.If the problem started after you replaced the plugs maybe you cracked one while installing it.
post #5 of 6 (permalink) Old Oct 30th, 01, 11:46 AM Thread Starter
It started befor the plugs and wires. the coil packs are new to, after this happened.
97/RS is offline
post #6 of 6 (permalink) Old Oct 30th, 01, 07:20 PM
You will have to have it checked out with a scope then to see whats up instead of us just 'guessing'what it might be.
