dead car - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 23rd, 01, 02:45 PM Thread Starter
currently having car repainted. int gutted moldings off etc. tried to start car (68 camero)everything dead lights, radio, wipers etc, battery checked out good . terminals are clean and tight. where do i start trouble shooting?
camarko is offline
post #2 of 4 (permalink) Old Apr 23rd, 01, 03:38 PM
check your battery cables and their connections.
boodlefoof is offline
post #3 of 4 (permalink) Old Apr 23rd, 01, 05:20 PM
Billy
check your main power wire it sounds like your problem. It connects to the battery at the positive post and is a red wire maybe a number 10 size wire.
'68 with a 355 and dart pro1 heads, XE284 comp cam, air-gap intake, th350 w/3000 stall and 3.73 gears.
'69 SS with a 427 with edelbrock alum heads, comp cam, performer rpm intake, with a muncie 4-speed and 4.11 gears
68and69ss is offline
post #4 of 4 (permalink) Old Apr 23rd, 01, 05:38 PM
Steven
don't forget negative bat cable connections ( both ends ) and grounding straps... Also, if EVERYTHING is dead, put a meter on the battery and check voltage...it is easy to leave door open or some other current drain when prepping and painting a car ...
sdtsdt is offline
