Vacumn advance pot crapped out?? - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 6th, 01, 07:17 PM Thread Starter
stevo camaro's Avatar
I think I know the answer to this but want your guy's input here. 454 with stock point dist. Been running under the weather lately. Check dwell, 40. Change that to 30, and put timing light on it. Showing me 22 intitial. Drop it down to 12. I did the timing with vac. advance plugged. With vac. advance unplugged engine at 3K RPM reaches 28 total. With vac. advance hooked up, the same. 12 initial, 28 total at 3K. Think my vac. advance pot crapped. What do you guy's say? I've noticed that "rocket launch" feel isn't a strong.
67 SS 396,4-sp
67 RS 327,4-sp
72 RS 350/350
69 4X4 suburban 350,4-sp
73 3/4 ton 454/400
Stevo Camaro's Toy
Our Muscle Cars
stevo camaro is offline
post #2 of 4 (permalink) Old Mar 7th, 01, 10:56 AM
The vaccuum pot is easy to check...remove the cap and rotor and the vaccuum advance hose...there is a rod that comes out of the vac pot into the distributor that is connected to the advance plate...push the rod as far as you can up into the vac pot, put your finger over the vac port on the pot, and release the rod, and if the rod goes back to its static setting then it is bad. Its not that uncommon.
375hp 78 Chevy truck
77 Chevy Nova
95 Chevy Lumina 3.4L
and building a 78 Nova
travis is offline
post #3 of 4 (permalink) Old Mar 7th, 01, 04:02 PM Thread Starter
Thumbs up
Thanks travis, I'll give that a try.
post #4 of 4 (permalink) Old Mar 7th, 01, 08:58 PM
David Pozzi
davidpozzi's Avatar
Smile
Sounds like it is gone..
At idle, plug the advance hose into a good vaccum source, the speed should go up. Or do that with a timing light on it and watch for advance.
They don't last forever!
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
