pinging and missing - Team Camaro Tech
post #1 of 9 (permalink) Old Mar 18th, 01, 12:10 PM Thread Starter
Cool
I have a 92 Camaro with a 305 tbi, when I sit at idle there is a slight miss in the engine sometimes, sometimes its smooth. Also I hear it pinging when I floor it. I've replaced the fuel filter, adjusted the timing, replaced cap, plugs, and wires. I am thinking maybe my injectors might be bad; they appear to be putting out a good misting halo, but I'm out of ideas. Any help would be appreciated.
jamesbern is offline
post #2 of 9 (permalink) Old Mar 18th, 01, 12:15 PM
check your egr system, the valve could be sticking intermittantly, causing a miss/skip noticeable at idle could also cause pinging problem. hope this helps.
71 camaro ss 66 chevelle 396/4spd www.americaniron.net
tom billings is offline
post #3 of 9 (permalink) Old Mar 18th, 01, 01:25 PM Thread Starter
Thank you I will do that.
post #4 of 9 (permalink) Old Mar 19th, 01, 03:19 PM Thread Starter
I checked the egr valve, but it is in excellent working condition and has not the slighest hint of carbon.
post #5 of 9 (permalink) Old Mar 19th, 01, 07:30 PM
when timeing the motor, dose the timing mark jump around??? if so a bad timing chain. also you could have a bit-o-carbon built up in the motor and you will get this too.
leaking valve guid's and or seal's can cause this too.
a minor vaccum leak at the intake too.
while idleing spray the intake manifold edges and with carb cleaner if the motor smooth's out you have a leak.
next un-plug the PCV valve. block off the hole and the fresh air inlet hole. soray sone carb cleaner into the vavle cover through the oil fill hole. if the idle change's you could have a intake leak on the inside or valve guid' leaking or valve guid seal's.
hope this help's.
ilbl8 is offline
post #6 of 9 (permalink) Old Mar 20th, 01, 02:28 PM Thread Starter
The timing chain is in good shape, we ran a complete topend cleaning on the engine, and I haven't yet found a vacuum leak though I will check some more. I am leaning towards the valve guides being worn out. The poor car has 187,000 on the orginal engine, but it was well taken care of. If I don't find any vacuum leaks I'll just assume its in the heads and not worry about it. I am planning on replacing that weak 305 anyway. I thank you gentlemen for your time and speedy answers and will let you know if I find the problem. Thanks again!!!!
post #7 of 9 (permalink) Old Mar 20th, 01, 06:08 PM
Are you using premium fuel? That might help the pinging. If you are not using it already...
1981Z28 1969Caprice396 1981TransAm Nascar Pace Car
TJMZ288 is offline
post #8 of 9 (permalink) Old Mar 20th, 01, 06:10 PM Thread Starter
The best I can get is 92 octane which should be sufficient, but I've tried dumping octane boost on top of that with no results. Today it didn't do it, yesterday it did, who knows?
post #9 of 9 (permalink) Old Mar 21st, 01, 01:38 PM Thread Starter
Cool
The problem was my oxygen sensor. Usually they overfuel and blow black smoke or have a smelly exhaust, but this one was different.
I'd like to thank you all for your help.
