instrument cluster - Team Camaro Tech
post #1 of 2 (permalink) Old Jun 19th, 01, 04:22 PM Thread Starter
1982 Camaro Z 28 305
Only gauge working is speedo
no fuel/amp/voltage/temp/tach
Also when headlights are on right turn signal is lit(only on instrument panel, not outside turn signals)
Also wondering if anyone knowas about installing intermitent wipers on my car. Can it be done and how difficult would the switch be
Thanks Guys
globb is offline
post #2 of 2 (permalink) Old Jun 24th, 01, 02:17 AM
On the turn signal problem, check to see if the bulb on either the front or rear is mislocated or in stalled in reverse. You can check that by turning the parking lights on. The incorrectly installed bulb will glow brighter than the rest. On the instrument cluster problem, check voltage and ground to the cluster. The problem is likely something common toall instruments. Ray
RABarrett is offline
