heating - Team Camaro Tech
post #1 of 4 (permalink) Old Nov 21st, 02, 02:12 PM Thread Starter
my 86 camaro's heater has started blowing
cool air only. new heater core was installed
6 months ago. any ideas??
chawkers is offline
post #2 of 4 (permalink) Old Nov 21st, 02, 02:20 PM
stevo camaro's Avatar
Water is not getting to it. Check the valve in the heater hose line to see if it's opening to allow water to flow.
Or, god forbid, there just isn't enough coolant in the system. It happened to me once in a 71 powerwagon with a 318. That's how I knew I was low on water. Hard to kill those 318's.
67 396 race car project
67 SS 396,4-sp mothballed for resto
67 RS 327,4-sp
72 RS 350/350, under current resto
69 4X4 suburban 350,4-sp
73 3/4 ton 454/400
Stevo Camaro's Toy
Our Muscle Cars
stevo camaro is offline
post #3 of 4 (permalink) Old Nov 21st, 02, 02:25 PM Thread Starter
hi steve it is my girlfreinds daughters car. where is this heater hose line. thanks chris
chawkers is offline
post #4 of 4 (permalink) Old Nov 22nd, 02, 04:38 PM
heater hose lines are coming right off the water pump. you do know where the water pump is, do you? if not, you can look under your hood and you will notice 2 black hoses clamped together wrapping around the passenger side of the engine going into the passenger side of the firewall. there is a "to"line going into the heater core and a "return" coming from the core back to the water pump. a quick test would be to unhook the to line fron the water pump and see if there is even water flowing through it. if there is water flowing through it, it will drain out.
nate is offline
