HEI Help - Team Camaro Tech
post #1 of 5 (permalink) Old May 6th, 03, 07:44 PM Thread Starter
My Mallory magnetic breakerless just blew two modules! So, I took it out and put in the original HEI from the ZZ4. Hooked it up to 12 volts and bypassed the resistor. My timing light is showing fire on the plugs, but the motor just spins with an occasional backfire(initial set at 10*) I can see plenty of fuel spray in the carb. I checked that #1 is at tdc after feeling compression at the hole and balancer is reading zero*
Anyone have any ideas? I'm getting real frustrated. It ran fine when I backed it into the garage to recurve the mallory. The only thing I havent checked is for bad fuel, I filled it up right before I brought it home last.
Any tests for the HEI???
Thanks in advance
67RS-zz4 w/ trickflow heads 276hr cam air gap 780 Pro Systems TexRacing 4spd AGR steering SCAT procars 12 bolt eaton posi 3.73's SSBC all around, TT2's Dakota Digital Painless DSE hinges
Mike's67 is offline
post #2 of 5 (permalink) Old May 7th, 03, 05:21 AM
Cool
Your timing light shows you have spark at the right time. You have plenty of fuel and air. only two problems I can think of at the moment, 1. Spark plugs are gas fouled, remove and blow dry the electrodes or replace with new ones, 2. Distributor might be 180* out, as in firing on cyl #6 rather than cyl #1. But, I'm sure #2 is out of the question as you stated finger @TDC comp and rotor is pointing to #1 wire.
post #3 of 5 (permalink) Old May 7th, 03, 08:41 AM Thread Starter
Now the engine will start and barely run. I have to feather the throttle to get it to around 1000rpm and as I give it more gas it pops and dies. Seems like it may be flooded now. But, I would think if it fired that it would have cleared up. I can't get the rpm's up enough to blow it out though
Mike's67 is offline
post #4 of 5 (permalink) Old May 7th, 03, 09:49 AM
Cool
Advance the base timing.
post #5 of 5 (permalink) Old May 7th, 03, 11:11 AM Thread Starter
Good advice Everette. It was at 5*ATDC. Runs good now. The motor twisted and the exhaust is hitting the seatbelt mount in the tunnel causing a hell of a racket now.
I geuss that's why we love these cars so much. They keep us so busy that we don't have time to think about all the trouble they cause.
Thanks for the advice [img]graemlins/thumbsup.gif[/img]
Mike's67 is offline
