Miss in 94 Camaro HELP!!! - Team Camaro Tech
post #1 of 2 (permalink) Old Jul 10th, 00, 11:23 PM Thread Starter
I have a 94 Camaro, 3.4l V-6, Problem is a engine miss during accel, have replaced plugs, plug wires, and fuel filter. Exhaust has good presure at idle so i don't think it could be an exhaust problem. I think it may be a senor problem but don't know where to start. The check engine light does not come one, and have tried to jump pins A and B to retreive codes but codes do not flash. any help would be greatful!
jer145 is offline
post #2 of 2 (permalink) Old Jul 11th, 00, 07:13 AM
if it is missing only under load, and you have replaced your plugs/ wires, what about the coil pack? , clogged injector? , ECM module? , just some more ideas.
Chris's 67 RS can be seen at http://www.geocities.com/macphreak4evr/index.html
JOIN THE CAMARO NET WEBRING! www.geocities.com/macphreak4evr/webring/webringjoin.htm !!!
Chris Edwards is offline
