high speed miss - Team Camaro Tech
post #1 of 7 (permalink) Old May 12th, 01, 08:07 AM Thread Starter
'69 Z-28, 350 eng, Holley 650, Accel dual point, getting a high speed miss, any ideas? Carb checked for needle / seats, float level OK, points set and OK....?
2quik is offline
post #2 of 7 (permalink) Old May 12th, 01, 11:47 AM
What rpm is it happening at?
craggar is offline
post #3 of 7 (permalink) Old May 12th, 01, 01:56 PM Thread Starter
Happening at about 3000 rpm on up.
2quik is offline
post #4 of 7 (permalink) Old May 12th, 01, 05:13 PM
Wink
its probably the points,when they work they work good, but if you don't keep up on them they are a PAIN!go with a form of HEI or the unilite from mallory(no clearance problems with this distributer). could be wires,or coil too. whats the compression test check out to be?
[This message has been edited by sldhd (edited 05-12-2001).]
sldhd is offline
post #5 of 7 (permalink) Old May 13th, 01, 03:59 PM Thread Starter
Have not done a compression check yet, but it seems to be running rich too; what are the symtoms of a bad power valve?
2quik is offline
post #6 of 7 (permalink) Old May 13th, 01, 06:19 PM
Cool
runs like crap at idle and part throttle. it will constantlt need to be "cleared out" at stop signs.
sldhd is offline
post #7 of 7 (permalink) Old May 16th, 01, 04:11 PM Thread Starter
Replaced the power valve, now it runs excellent!
2quik is offline
