67 windshield washer pump priming? - Team Camaro Tech
post #1 of 6 (permalink) Old May 10th, 04, 07:23 AM Thread Starter
Denis
I just installed a restored 67 windshield wiper motor and washer pump. Wipers work okay but pump isn't squirting (yes, there's washer liquid in the jug). Do I need to "prime" the windshield washer system somehow?
deejaygee is offline
post #2 of 6 (permalink) Old May 10th, 04, 08:16 AM
I don't recall ever having to prime the system, but it probably wouldn't be a bad idea. Make sure that the sqirter ends and pickup screen are open and not clogged and that the system is not drawing air from someplace.
'67 SS/RS (RR)
'68 RS conv. (J2)
'68 Z/28 (VV)
'68 Drag Car(ZZ) 11.30 @ 118
'73 Corvette Drag Car 12.64 @ 106
Kyvox is offline
post #3 of 6 (permalink) Old May 15th, 04, 08:31 AM
I took my whole windshield washer system apart to fix it. I took the pump apart and cleaned and lubed everything. Make sure the little rubber diaphragm is working. Put it all back together with new hoses, fitting, etc. Don't overlook the ends that squirt onto the windshield, they could be blocked or bent, causing a restriction.
Then, it took a long time for the pump to "self-prime"...running it until the liquid fills everything and finally hits the windshield. After you have it working, remember to use it every once in awhile to keep it primed and working. Don't know if this is the answer you seek....but it worked for me!
Steve W
1968 Camaro Convertible
1966 GTO Convertible
1995 Harley Road King
"You can't always get what you waaant..."
Steve W is offline
post #4 of 6 (permalink) Old May 15th, 04, 01:11 PM Thread Starter
Denis
Good advice. Thanks.
Like you, I took everything apart, cleaned and lubed, and put new plumbing and white end on the pump.
I did prime the system up to the pump by using a simple hand-operated vacuum pump but still no go.
I can hear the mechanism working but I didn't check the diaphragm. I'll bet it's the diaphragm or the plumbing going to the windshield.
post #5 of 6 (permalink) Old May 15th, 04, 05:14 PM
Sounds like one of the rubber valves is installed backwards, broken, plumbing hooked up wrong, or missing O-ring or something.
dnult is offline
post #6 of 6 (permalink) Old May 4th, 06, 07:08 PM
Darin
Re: 67 windshield washer pump priming?
Did you ever get your pump working... I am having the same problem as you did right now.
Darin Imbriaco is offline
