msd timing adjustment - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 26th, 01, 06:34 PM Thread Starter
first question: is msd really worth it? second question: how do i set initial timing with a 6a box? theres no "vacuum advance" to disconnect. hows it work
jbweldin is offline
post #2 of 6 (permalink) Old Apr 27th, 01, 03:19 AM
First question, yes.
Set the inital timing with a timing light, and at idle, you would like to see 14-16.And then setup a total of around 36, and if that is to much,back it down in two degree increments until the pinging stops.
383 Speed-O-Motive stroker kit with Speed Demon 750, RPM intake,Proform HEI dist.MSD6a box,World Products Sportsman II heads, ported and polished with 2.02/1.60 valves,64cc,TRW forged pistons with 10.7:1 compression, Comp Xtreme 284 cam,Crane pushrods, Comp Cam 1.6 full roller rockers,ATI damper, 40 series Flowmasters, 4.11 gears with TH350 and Hughes 3000 stall.Powertrax NoSlip Locker
Tracy Focht is offline
post #3 of 6 (permalink) Old Apr 27th, 01, 03:43 AM
Thumbs up
Just installed 6AL, Blaster 2, and Pro Billet Distributor - Works great!!!! Careful how you hook up tach., you may need an adapter.
I still time things the hillbilly way - Advance until it pings under load, then retard until it stops pinging. Seems to work just fine when I check it with a light.
1stgenZ is offline
post #4 of 6 (permalink) Old Apr 27th, 01, 06:05 PM Thread Starter
Talking
thanks guys, that helps me out quite a bit. for a while there, it was beginnning to look bad for my MSD, i was seriously thinking about gettin rid of it and going back to HEI
jbweldin is offline
post #5 of 6 (permalink) Old Apr 27th, 01, 07:53 PM
Thumbs up
have ran msd systems for lots of years. Great products, but can cause lots of headache if you have something wrong. The tech guys at MSD in ElPaso are lifesavers for most any problem. They all know their products very well, and most of them also run them, give them a call with anything you need. They REALLY are Very helpful! If they cant get you fixed up over the phone, they will replace or repair your products, or refund you. We have found that after purchasing a system, we have never been left hanging, and anything that was ever in need of repair was done very affordable, and sometimes free. Keep your msd!
camaromom is offline
post #6 of 6 (permalink) Old Apr 28th, 01, 12:55 AM
one little side note.... be sure you have good plug wires or the hotter spark will arc, trust me on this....
My '68 Camaro
Doug G.
68 Camaro
406 ci.
