95 Z won't start - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 6th, 01, 11:49 AM Thread Starter
Exclamation
I have a 95 Z28. The engine turns over but will not start. There is a ticking sound that sounds like a spark arching. It had been ticking for a couple of days when starting but was ok when it started. The car has a new MSD 6AL ignition with a blaster coil. It isn't the starter or the battery. Also the voltmeter reads 8-9 volts when starting.
peachtree95z28 is offline
post #2 of 3 (permalink) Old Feb 6th, 01, 03:53 PM
Have you checked the injectors? Check to see if you're getting fuel. Also check to see if you're getting spark.
Inspeccter is offline
post #3 of 3 (permalink) Old Feb 7th, 01, 11:56 AM Thread Starter
I know i am getting fuel but I have not had a chance to check spark. I do know that the car started a few times even when the ticking could be heard. Could it be the ignition module? or maybe the MSD ignition is bad? I will check for spark tonight. I'm pretty sure that it is an ignition problem. If you have any ideas, I'm all ears. Thanx.
