Carb Woes - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 1st, 01, 09:56 AM Thread Starter
Angry
Hello everybody I am having trouble with my holley 800 cfm carb on my BBC. It tends to load up at idle and also does this weird thing, if you blow it out (rev it up) then let it idle, it will idle high for a while (10-15 seconds) and then slowly come down to the idle speed. I have checked for vacuum leaks and come up with nothing on the carb but I don't really know how to test the mani or if that is even the problem. please help!!
BRY67 is offline
post #2 of 6 (permalink) Old Feb 1st, 01, 11:11 AM
Adjust your float bowls, sounds like your primaries are hanging up. Do you have external sight plugs?
Chris Maher is offline
post #3 of 6 (permalink) Old Feb 1st, 01, 11:55 AM
It sounds to me that the power valve in the Holley is blown. It will produce the problem you are describing. I went to Carters along time ago for that issue.
68 RS red w/ white stripes
67 SS/RS restoring
camaroguy is offline
post #4 of 6 (permalink) Old Feb 1st, 01, 12:05 PM Thread Starter
Really, you think the power valve is blown? that could be it, the funny thing is I replaced it with a different size just before this started happenning mabe I got a bad one I will try that thanks!!
BRY67 is offline
post #5 of 6 (permalink) Old Feb 1st, 01, 12:32 PM
DjD
DjD's Avatar
Maybe the power valve is ok and the effect is from the size change. Did you make any other changes? What problem were you trying to over come with the size change?
...Dennis
The Cars:
'69 RS Convertible w/SS trim
'96 Z28SS #1679 of 2410
The Club:
Camaros Limited Nor-Cal
DjD is offline
post #6 of 6 (permalink) Old Feb 1st, 01, 01:12 PM Thread Starter
Well, I adjusted the size in accordance to the vaccume guage, the cam is good sized and the power valve would be opening at just off idle and you don't want it to open till at least three quarter throttle for good gas mileage then let the valve open to give power enrichment at WOT. I think the valve was bad when I put it in I bought it from a place where it had been sitting for quite some time so I think it may have been dry to begin with.
BRY67 is offline
