My 2.8 is toast - Team Camaro Tech
post #1 of 3 (permalink) Old Feb 5th, 01, 04:17 PM Thread Starter
Unhappy
My 1985 2.8L Camaro's engine would probly win the worst noise ever herd from an engin award. It has a bad banging sound at idle speeds and gets louder as the engine speeds increase (2000 RPM's you can't here your self think). I think its a bad wrist pin or piston rod.
oil pan 4 is offline
post #2 of 3 (permalink) Old Feb 5th, 01, 04:39 PM
Freddie
Bet it's a rod bearing. The older 2.8s had a bad oiling system. The rod bearings don't get enough oil. This was improved in later versions.
'69 RS/SS396 pro street
427/4spd/9"
big gear head is offline
post #3 of 3 (permalink) Old Feb 5th, 01, 10:30 PM
also the cam has oiling problem's and they like to break! then they crack the block!
get a 3.4 cam for the 3.4 upgrade motor for the S-10's that GMPP offer's and rebuild the bottom end and head's...or better yet get a 3.4 GMPP motor if you want to keep the 6 banger, they work great!
ilbl8 is offline
