REVERSE BACK-UP SWITCH question - Team Camaro Tech
post #1 of 4 (permalink) Old Dec 6th, 99, 12:56 PM Thread Starter
i am swapping in a 78-4-speed trans in my 70 camaro it has the back-up lamp switch on the trans,has anyone swapped in a late model tranny in a early camaro (wiring question i guess)the normal back-up was switched using the lever on the steering column with linkage coming from trans(which i dont have?)...thanks in advance..
70camaro(350)ground-up restification,350 slightly modified
doug70 is offline
post #2 of 4 (permalink) Old Dec 11th, 99, 04:22 PM
Look for the wires that would go to the coloum switch, light green (I think)extend these wires to the switch on the trans mission, this switch should have two terminals,
Rob.Canada is offline
post #3 of 4 (permalink) Old Dec 11th, 99, 04:22 PM
post #4 of 4 (permalink) Old Dec 12th, 99, 05:29 AM Thread Starter
i am trying to locate all the reverse lock-out linkage and try that route ,70-81 manual trans,also looking for the bracket (saginaw 4-speed) that holds reverse linkage and lower reverse lock-out rod..thanks...
doug70 is offline
