hesitant - Team Camaro Tech
post #1 of 10 (permalink) Old Oct 29th, 01, 07:09 AM Thread Starter
i need some help.i own a 94 z28.when i'm driving and pressing down on the gas only slightly,it runs kind of rough and feels hesitant,but when i push the gas farther down it feels and runs fine.anybody have any idea of what could be wrong?
st20 is offline
post #2 of 10 (permalink) Old Oct 29th, 01, 08:52 AM
Poss overactive EGR valve, If its Vac operated.
Milan is offline
post #3 of 10 (permalink) Old Oct 29th, 01, 01:58 PM
Stephen Dale
Guest
Posts: n/a
The TPS may have a dead spot. Check with a DIGITAL ohm meter. Do you get any OBD codes?
67 Nemesix
post #4 of 10 (permalink) Old Oct 29th, 01, 04:20 PM Thread Starter
no codes.it is most noticible goig up hill.
st20 is offline
post #5 of 10 (permalink) Old Oct 30th, 01, 07:54 AM Thread Starter
after paying real close attention,i've realized that it only runs that way at 45mph and 1500rpm.it even does it on cruise control.you can see the rpms jump slightly.
st20 is offline
post #6 of 10 (permalink) Old Oct 30th, 01, 08:11 AM
ZZ_430's Avatar
Is it a 6 speed or automatic?
Don~ ZZ430DropTop
~~~~and~~~~
Pro-Touring.com DropTop
67 RS/SS Convertible, 70 RS/Z28
ZZ_430 is offline
post #7 of 10 (permalink) Old Oct 30th, 01, 09:08 AM Thread Starter
AUTOMATIC
st20 is offline
post #8 of 10 (permalink) Old Oct 30th, 01, 09:41 AM
ZZ_430's Avatar
Ok, I'm thinking about torque lock-up operation. Try putting shifter in "D" rather than "OD" and see if that makes any difference.
Don~ ZZ430DropTop
~~~~and~~~~
ZZ_430 is offline
post #9 of 10 (permalink) Old Oct 30th, 01, 10:14 AM Thread Starter
in does it in D at 50mph 2000rpm,but it's really only noticible going uphill.it's not nearly as bad as overdrive.
st20 is offline
post #10 of 10 (permalink) Old Oct 30th, 01, 03:35 PM
it might be your opti-spark
97/RS is offline
