fast burn won't start - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 19th, 03, 09:30 AM Thread Starter
i just finished putting a hot cam and rockers in my fast burn it ran for about a hour than a huge puff of gas came out of the secondaries and has not started again help. running msd 8474 direct to fuse box on coil . have 12 volts at coil and juice to cap . carb 770 holley
[ 04-19-2003, 12:54 PM: Message edited by: sandycat ]
sandycat is offline
post #2 of 4 (permalink) Old Apr 19th, 03, 11:54 AM
ZZ_430's Avatar
Start by pulling the spark plugs, and check for fouling. Double check fuel pressure and carb float levels.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #3 of 4 (permalink) Old Apr 19th, 03, 12:25 PM Thread Starter
okay thank you. for the results first two plugs were oil filled dripping wet and the second before it shut down just adjusted the fuel level in the sight glass to half way up but it would not go lower .
i had 6-7 pounds of fuel pressure .
[ 04-19-2003, 06:27 PM: Message edited by: sandycat ]
sandycat is offline
post #4 of 4 (permalink) Old Apr 22nd, 03, 03:27 PM Thread Starter
i finally got it started. but it took putting back original gm hei distributor
sandycat is offline
