Barely running - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 9th, 03, 10:27 AM Thread Starter
I have a 69 SS 396 that I replaced the timing gears with a double roller chain, had larger 2.19/1.88 valves put in the heads. The problem is when I start the car it barely starts and runs like crap. I move the distributer back and forth and the best I can get it to run is at 16 deg. BTDC. When I put the distributer back in initially I set the #1 to TDC and pointed the rotor to that wire on the cap. I verified the wires and they are all separated and in the correct order, the carb has not been touched from before I tore it down.
Something else interesting is the #1 and #6 plugs seem to be fouled. I am running a Comp Cams XE 274 cam and Hydrolic lifters. I adjusted the lifters so using the EO/IC method and they seem to be ok.
Does anyone have any suggestions? I am at a loss here. I think I have done just about everything I know to do but for some reason this thing is not working. Any help will be gladly appreciated.
Team Camaro Gold #137
Team Chevelle 1856
ACES #6768
69 Camaro SS396. Hugger Orange, Holley MPFI, TKO600 5spd, 12 Bolt 3.55.
sgaylord is offline
post #2 of 3 (permalink) Old Apr 9th, 03, 04:06 PM Thread Starter
Smile
Well I think it's fixed. A friend came over and it appeared I had a few valves adjusted a little too tight. We adjusted them and set the timing and it appears to be running alot better. I can take it out yet because I need to finish a few things.
Thanks for reading my post. I hope if anyone else has this particular problem this will help in some way.
Thanks,
Team Chevelle 1856
ACES #6768
sgaylord is offline
post #3 of 3 (permalink) Old Apr 9th, 03, 05:33 PM
Hope that took care of it. [img]graemlins/thumbsup.gif[/img]
Good luck with the project.
- '68 Chevy Camaro (sort of done, but always subject to improvement)
- '63 Pontiac Tempest (work in progress)
- '72 Datsun 240-Z (back-burner for now)
boodlefoof is offline
