rear end noise in 91 RS - Team Camaro Tech
post #1 of 2 (permalink) Old Nov 28th, 01, 11:52 AM Thread Starter
Unhappy
I have a 91 RS, and i just got done putting all new bearings in the rear end, mainly pinion... i had a noise that sounds like a soing machine.... but with more of a rattle.. the noise goes away when in neutral or when not heavy ont he gas, just under power... anyone have any suggestions whats wrong???
JMW
winnicki is offline
post #2 of 2 (permalink) Old Nov 30th, 01, 10:38 AM
Joe
Did you install the pinion nut with the right amount of preload or did you just get it real tight? Sounds almost like the pinion nut is to loose which will cause noise and will wear out the bearings and gear set real quick.
70 camaro 307 (350soon) /350th
Joekool1234567 is offline
