73 camaro wont start - Team Camaro Tech
post #1 of 9 (permalink) Old Nov 15th, 00, 04:54 AM Thread Starter
I have a 73 camaro that at one time ran great. It has sat garaged for about 4 years having been started 2-3 times during that period. Now after putting in a carb kit, coil, points, condensor and new battery I cant get it to start. Starter is turning motor but no sign of it trying to kick in. I know gas is flowing into carb. I tried to check spark from coil but do not see any. Other than checking wiring leading to coil does anyone have any other suggestions? Also, Is there a way to check if timing chain is broken without dismanteling and removing cover? Thanks for any help.
gateruner is offline
post #2 of 9 (permalink) Old Nov 15th, 00, 05:50 AM
Pull a valve cover and watch the rockers as the motor is cranking. If they move, the chain is not broken.
1992 Firebird 355/Six Speed
1991 RS 350 / 700-R4
1987 Toyota Pickup 383 / 500 + HP 10.963 @ 119.95 Slicks / 11.997 @ 114.23 Radials
http://personal.lig.bellsouth.net/~racer383/
Mark W. Winning is offline
post #3 of 9 (permalink) Old Nov 15th, 00, 01:25 PM
Bill
Even quicker...pull the distributor cap and see if the rotor turns when you crank the motor.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #4 of 9 (permalink) Old Nov 15th, 00, 02:24 PM
Check the compression.
1st & 2nd GENGuy is offline
post #5 of 9 (permalink) Old Nov 16th, 00, 01:29 AM
double check your point gap. change your coil/borrow one that you know works. i would seriously doubt your timing chain breaking.
[This message has been edited by ls777z (edited 11-16-2000).]
ls777z is offline
post #6 of 9 (permalink) Old Nov 16th, 00, 02:28 AM
Bill, DUH! what was I thinking...
Major brain fade.
post #7 of 9 (permalink) Old Nov 16th, 00, 03:48 AM
put some new gas in it
DEVIL'S LAKE is offline
post #8 of 9 (permalink) Old Nov 16th, 00, 10:58 AM
Yea, that new gas will really make it spark.
kz1000ltd is offline
post #9 of 9 (permalink) Old Nov 17th, 00, 03:42 AM Thread Starter
Cool
Thanks for all your help. I have a feeling I know where I dropped the ball. Hopefully it will be simple as setting the points gap.
Thanks and Race on.
