checking secondaries on 4bbl - Team Camaro Tech
post #1 of 3 (permalink) Old May 17th, 01, 08:35 PM Thread Starter
Unhappy
I have an '83 Z28 w/ 305 and 4bbl, I'm experiencing prob's similar to previous post "backfiring out the carb". The car feels like it's only driving on 2bbls. My question - how do I check the accel pump? With engine off when should I see spray from both front and back, right now the front is squirting great but I don't see much spray in back even pumping the throttle all the way back & forth. Thanks for your help/comments.
magpi is offline
post #2 of 3 (permalink) Old May 18th, 01, 02:22 AM
Q jet carbs rear pump does not operate like the fronts. It operates from the depression created by the opening of the secondary air valves. As they open in relation to air demand, the space created by the valve and the air horn casring creates a depression which pulls fuel through an opening in the casting. If the engine is not running, it will not create any deprerssion, hence, no fuel flow. The easiest way to check secondary operation is to mechanically move the air valves and check the operation of the secondary metering rods, making sure they move with the air valves. Ray
RABarrett is offline
post #3 of 3 (permalink) Old May 18th, 01, 05:34 AM
He has a Holley.
68 RS, Ash Gold,pwr windows,Hounds tooth,355/T350,Autometer guage pod
CA420 is offline
