missing - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 8th, 03, 02:26 PM Thread Starter
hello, i need some help. I had an oil leak coming from back of intake, so i pulld it and replaced gaskets, fixed that problem, now it misses when taking off from a stop, but if at 40mph and nail it, it just misses a tiny bit, thenscreams, its real bad from a stop though, i thought vacuum leak but got 20 inches on vacuum guge, can it be a dirtyfuel filter, plugs are all clean. this is a 400 .20 over, 882 heads, stock mnifolds, rpm intake, 600 edelbrock, comp 268 cam, 9.2 cr. thanks
mylittle307 is offline
post #2 of 3 (permalink) Old Mar 9th, 03, 07:51 AM
It won't take much of a leak to lean the mixture and still give you good vacuum. Especially if the leak is on one cylinder only.
-dnult
dnult is offline
post #3 of 3 (permalink) Old Mar 10th, 03, 09:27 AM Thread Starter
w,fixed it, tuned out to be a dirtyfuel filter, thanks
