still running rich - Team Camaro Tech
post #1 of 6 (permalink) Old Mar 22nd, 01, 05:25 PM Thread Starter
I have a 1989 iroc 305 tpi.The engine is running extremly rich.I have had the mas,oxygen,tps.iac sensors checked and reset.Changed temp sensor,air temp sensor,ignition module,plugs,dist.cap, rotor,wires.Also had timing checked.computer also checked good.Changed The fuel reg. too.It will run fine for a minute then start running rich.Could the egr cause this?It's the only thing left.I need some help!Running out of sanity and money.
willis2z is offline
post #2 of 6 (permalink) Old Mar 23rd, 01, 02:27 AM
Lightbulb
try cleaning out your vaccuum lines to the egr valve and egr solenoid with carb cleaner.also check to see if you have any loose bolts on the tpi manifold especially around the plenum chamber, runners, and throttle body and covers. also check condition of the rest of your vaccuum lines
trickster is offline
post #3 of 6 (permalink) Old Mar 23rd, 01, 04:56 AM
sounds to me like you have a broken wire or a bad conection some where. or a bad ground .
superpro69 is offline
post #4 of 6 (permalink) Old Mar 23rd, 01, 03:38 PM
If it is skipping. check for broke valve spring if it has one broke it will act like it is flooding but you will not find any sencers bad.
melrod is offline
post #5 of 6 (permalink) Old Mar 23rd, 01, 06:59 PM
David Pozzi
davidpozzi's Avatar
Make sure the vacum line to the fuel pressure regulator is providing vaccum to it.
I have seen some small vac lines plug with gummy carbon from EGR on TBI units, might happen on a TPI.
Is the fuel pressure going up when it goes rich?
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
post #6 of 6 (permalink) Old Mar 24th, 01, 03:17 AM Thread Starter
Thanks for all of your reply's.I dicovered a bad ecm after all.replaced it and the car runs great.Thanks again for your help.
willis2z is offline
