Carb Icing??? - Team Camaro Tech
post #1 of 5 (permalink) Old Jan 17th, 01, 03:57 AM Thread Starter
Exclamation
OK Here it is...I drove the car to work...30 miles, got there and looked under aircleaner to see if there was gas driping down and I found ICE! Ice on the buterflies, so how do I stop that?
Life begins at 140...especially in a 1967 Camaro Z28!!
check out my car at www.spiralcomm.net\landjjohn\camaro
joeyj is offline
post #2 of 5 (permalink) Old Jan 17th, 01, 09:30 AM
first off...the temp around the butterfly's is below freezing when runing...physics rember that from highschool never thought you would need that hu??LOL, iceing is normaly a sign of watter in the fuel or a cold manifold/carb, you need to have a warm manifold and carb to get good fuel atomization and in the winter if you have blocked off or non exsisting heatriser pasage you can get this problem. try a diferant brand of fuel, and or put a OEM aircleaner off a pick up with the hot air system, you know the little stove pipe from the header or exaust manifold to the snorkle with a divritore in the snorcale that work's off of a vacum valve.you only need a set up like this in the winter..take it off in the spring when the temp's are above 40 deg. this is only for driveability...you will take a slight performace drop not much maybe oh, 10 horses and 15 foot pounds of torque. but the carb will not ice up and it will drive better in the cold weather.
we tend to set our performance cars up for warm summer driveing..and forget that in the winter they have a few problem's not faced in the summer. hope this help's and good luck!
ilbl8 is offline
post #3 of 5 (permalink) Old Jan 17th, 01, 01:07 PM
Just warm it up with one of the map gas torches. Or then again, maybe not....
LOL
We run a few alky cars and these freeze real bad sometimes.
1992 Firebird 355/Six Speed (Soon to be LT1)
1991 RS 350 / 700-R4
1987 Toyota Pickup 383 / 500 + HP 10.963 @ 119.95 Slicks / 11.997 @ 114.23 Radials
"Speed KILLS, so drive a FORD and live forever!"
http://personal.lig.bellsouth.net/~racer383/
Mark W. Winning is offline
post #4 of 5 (permalink) Old Jan 17th, 01, 03:47 PM
Bret
Wink
I prefer chocolate icing!!
I'm too much of a smart a$$ for my own good somtimes Are you running an open element air cleaner? Maybe switching to an "enclosed" type would help-at least during the cold months?
Bret Copsey
'68 Camaro base coupe
'92 Caprice wagon
'98 Malibu
[This message has been edited by bretcopsey (edited 01-17-2001).]
bretcopsey is offline
post #5 of 5 (permalink) Old Jan 18th, 01, 08:22 AM Thread Starter
Thanks for the info guys...actually I was going to run a generator in the trunk....and mount my wifes hairdryer on top of the carb..
To answer your questions yes I have an open element airfilter and I dont think my new manifold even has an exhaust crossover. A bad combo when it is 25 degrees outside!
joeyj is offline
