Water pump noise - Team Camaro Tech
post #1 of 8 (permalink) Old Jul 12th, 14, 12:06 PM Thread Starter
Dan
Water pump noise
Need some help. My sbc started to make a knocking noise at the front of the engine. After troubleshooting and pulling the pulley off of the water pump I noticed the main shaft on the water pump that the pulley bolts to has some slack. It also makes the same noise when I push on it and move it around as when the engine was running so I know this is the problem. Question is can that be repaired or should I just replace the pump? It's about 7 years old and the engine has less than 5K miles on it.
Carbo is offline
post #2 of 8 (permalink) Old Jul 12th, 14, 01:33 PM
Ty
69&76's Avatar
Re: Water pump noise
Replace the pump... so much easier. WP are not that expensive.
69&76 is offline
post #3 of 8 (permalink) Old Jul 12th, 14, 01:51 PM Thread Starter
Dan
Yeah, that's what I'm doing as we speak. Getting ready to drain the radiator right now.
Carbo is offline
post #4 of 8 (permalink) Old Jul 12th, 14, 02:35 PM
Ty
69&76's Avatar
When you are done, treat yourself to the best Italian restaurant in Vegas...Pieros.
69&76 is offline
post #5 of 8 (permalink) Old Jul 12th, 14, 07:24 PM
Roger
rogerh's Avatar
How can the bearings be that bad without the pump leaking?
The only reason to rebuild your pump would be if it was original to the car or correct dated pump. Otherwise just replace it.
Roger
rogerh is offline
post #6 of 8 (permalink) Old Jul 12th, 14, 07:43 PM Thread Starter
Dan
Roger
Yeah, just picked one up from Oreilly (murray water pump) for $28.00.
Carbo is offline
post #7 of 8 (permalink) Old Jul 12th, 14, 09:37 PM
Chad
cv2065's Avatar
I had the same thing. No leaks in the WP, but slack in the main shaft. Was so bad that the fan blades were grazing the shroud with higher RPM's. Was also causing a vibration throughout the cabin between 55-65mph. Replaced and all is good.
67 Black RS Coupe, 383, M21 & 10 Bolt Posi. Edelbrock E-Tech 170 Heads, 2204 Roller Cam, Air Gap Intake.
cv2065 is offline
post #8 of 8 (permalink) Old Jul 13th, 14, 05:48 AM
It's a common test to grab a fan blade or pulley and see if you get movement or clunking out of the shaft. If you do, the pump is not long for this world.
Sent from my iPhone using Autoguide
Melrose RS is offline
