Is this bad? - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 17th, 14, 10:44 AM Thread Starter
Russ
Russ-67-427's Avatar
Is this bad?
Hoping for the best!
I just changed the break in oil on my ZZ427 after fifty miles of easy to moderate cruise.I primed the engine and used 5w30 non synthetic for break in.
I flipped the oil filter into a clean container overnight and found very light flakes in the base of the container.
Is this normal break in material or something more serious?
Engine runs fine with no knocks but does have a slight lifter tic.
Any concerns?
Name:	Break in oil 004.jpg
ID:	84042   Click image for larger version
Name:	Break in oil 005.jpg
ID:	84050   Click image for larger version
Name:	Break in oil 001.jpg
Name:	Break in oil 003.jpg
ID:	84066   Click image for larger version
Name:	Break in oil 002.jpg
Russ-67-427 is offline
post #2 of 4 (permalink) Old Aug 19th, 14, 06:02 AM
Karl
VetteFreak's Avatar
Re: Is this bad?
This is normal during break in. I wouldn't worry just yet, but, if you're really concerned send it to Blackstone Labs for analysis. Is the valve tick throughout the entire valve train or is it just one lifter? You may have a stuck lifter causing the cam lobe to slap the lifter resulting in premature wear. Dunno!
Karl / VetteFreak
69 Camaro RS 350/350TH...Burgundy...711-Black Int/Houndstooth Seats
2007 Corvette Conv. LS-2/A6...Monterey Red/Black Top & Int
VetteFreak is offline
post #3 of 4 (permalink) Old Aug 19th, 14, 02:02 PM
Steps
Re: Is this bad?
Re check the tappet settings.. those head torques valley cover torques all require re checking...
I cant really make out exactly from the picks, but a little very fine 'metal flake' like a fine paint metal flake is normal ... things like rings beding in
Steptoe is offline
post #4 of 4 (permalink) Old Aug 19th, 14, 03:02 PM
Sean
Re: Is this bad?
You are always going to have some wear initially til everything mates to one another. Scary though if you have never experienced that before. Also as stated, you will want to recheck lash on the rockers. Generally after break-in, stuff wears in a bit, and you should not have to reset after this for a while.
1967 RS/SS Camaro 383 5 speed tremec 3.70
1967 RS/SS Camaro 383 5 speed tremec 4.10
1967 RS Camaro Convertible 327 4 speed 3.73
1969 SS Camaro 6.0 LS Twin Turbo 5 Speed 3.50
2013 ZL1 Camaro roto-fab airbox pulley swap Rest In Pieces March 27 2014
FTF Automotive is offline
