Dwell setting - Team Camaro Tech
post #1 of 12 (permalink) Old Nov 1st, 14, 07:56 PM Thread Starter
Dan
Dwell setting
Months ago I initially set my dwell at 32, initial timing at 4b and now went to check all settings and dwell is around 18-20. If I try to set it to 32 it stalls out at around 25.
What's up here?
Thanks for any help!
69 LeMans Blue X77 Z28 (SOLD)
68 Corvette Bronze RS Z28
68 LeMans Blue SS 396 L78 (9978 orig miles)
DDZ28 is offline
post #2 of 12 (permalink) Old Nov 1st, 14, 08:01 PM
69-Pace's Avatar
Re: Dwell setting
What is you initial timing now?
Sent from my iPhone using Autoguide
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 12 (permalink) Old Nov 1st, 14, 08:11 PM Thread Starter
Dan
Re: Dwell setting
4b
DDZ28 is offline
post #4 of 12 (permalink) Old Nov 1st, 14, 08:15 PM
69-Pace's Avatar
Re: Dwell setting
how are you reading the dwell with a feeler or digital meter?
69-Pace is offline
post #5 of 12 (permalink) Old Nov 1st, 14, 08:28 PM
Jon
Re: Dwell setting
Easy to remember;
If the dwell number is too small, the points are too wide.
I know that isn't what you asked, but it may help in your diagnosis.
Jon N
dyno jonn is online now
post #6 of 12 (permalink) Old Nov 1st, 14, 09:01 PM Thread Starter
Dan
Re: Dwell setting
Digital multi-function timing light
DDZ28 is offline
post #7 of 12 (permalink) Old Nov 1st, 14, 09:28 PM
ZZ_430's Avatar
Re: Dwell setting
Bump up your initial and try setting the dwell to 30.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #8 of 12 (permalink) Old Nov 1st, 14, 09:38 PM
Kev
Re: Dwell setting
This may not be helpful--my attempts at helping often end in my being asked to stop...
But, dwell and point gap are the same things measured differently. Just look at what the dwell adjustment adjusts. Point gap.
Changing dwell/gap impacts timing slightly, but not the other way around.
67sc is offline
post #9 of 12 (permalink) Old Nov 2nd, 14, 05:56 AM
Re: Dwell setting
New points - 30* dwell, used - 28*.
Set your initial timing between 14-16* BTDC. When the factory set the timing it was to pass emission tests back in the day and so you wouldn't blow the engine up under warranty. If you want the car to run like a turtle then use the factory timing specs.
COPO is offline
post #10 of 12 (permalink) Old Nov 2nd, 14, 06:53 AM
Lynn
Re: Dwell setting
What's up here?
My first guess is that your meter is or was incorrect.
As the point block wears, the dwell # goes up (more narrow point gap).
Pull the cap and set them with a feeler gauge.
Lynn
bilodeaulynn is offline
post #11 of 12 (permalink) Old Nov 2nd, 14, 06:57 AM
Steiner
Re: Dwell setting
One degree of dwell change results in two degrees of timing change. Since you're increasing dwell, timing will retard. Not a surprise it stalled out. When it's off by more than a couple of degrees you have to jump back and forth between timing and dwell.
'69 Camaro
500hp/538lbft
Steiner is offline
post #12 of 12 (permalink) Old Nov 2nd, 14, 09:21 AM
Re: Dwell setting
Set the points first then the timing.
COPO is offline
