irocz will not start - Team Camaro Tech
post #1 of 10 (permalink) Old Nov 29th, 14, 05:35 AM Thread Starter
chris
Hi Guys
Hope anyone can help, I have an 89 350tpi iroc z . It will not start. I have replaced the coil, distributor, leads and plugs. I have power to the coil but no spark from the coil or injectors. I have triple checked all connections are made.
I have no idea why it wont fire
red89 is offline
post #2 of 10 (permalink) Old Nov 29th, 14, 08:17 AM
Lonnie
Lonnie P's Avatar
Re: irocz will not start
The pickup coil in the distributor can fail & somewhat commonly do.
You can check resistance across the coil leads to see if there is an open circuit.
Distributor must be removed & disassembled to change.
Lonnie P is offline
post #3 of 10 (permalink) Old Nov 29th, 14, 12:56 PM Thread Starter
chris
Hi thanks for the reply, As I stated the coil and distributor are brand new so thats not the issue. I have 12 volts from the ignition to the coil but when I tested the 2 pin connector at back of distributor I only get 5 volts not 12 volts
red89 is offline
post #4 of 10 (permalink) Old Nov 29th, 14, 01:55 PM
Lonnie
Lonnie P's Avatar
I misinterpreted thinking you replaced the distributor cap, not the entire distributor.
Lonnie P is offline
post #5 of 10 (permalink) Old Dec 1st, 14, 09:54 AM
Karl
VetteFreak's Avatar
Originally Posted by red89 View Post
Hi Guys
Since you replaced the distributor and everything is new, are you absolutely sure you connected the 4 wires running from the distributor to the ECM in their proper locations? If the wires are correct, then, the ECM may be the problem.
Karl / VetteFreak
69 Camaro RS 350/350TH...Burgundy...711-Black Int/Houndstooth Seats
2007 Corvette Conv. LS-2/A6...Monterey Red/Black Top & Int
VetteFreak is offline
post #6 of 10 (permalink) Old Dec 1st, 14, 10:24 AM
Billy
Just because the above items are new...doesnt mean they are good . I would have the coil and spark control module etc checked.........
member since 2002
Billy d. is offline
post #7 of 10 (permalink) Old Dec 1st, 14, 05:01 PM
A very common problem for the third gens are the VATS ( security) system. There is a wire from your ignition key cylinder that breaks and doesn't send the reading from your chip in your ignition key to the VATS system. Car won't run. They do make eliminator kits, but you must know your OHM reading from your ignition key. Google is your friend
never2manycamaro's is offline
post #8 of 10 (permalink) Old Dec 1st, 14, 07:11 PM
Lonnie
Lonnie P's Avatar
When the VATS is active, the car will not crank as it also disables the starter circuit.
Ohm out your pickup coil... even if it is new.
Lonnie P is offline
post #9 of 10 (permalink) Old Dec 1st, 14, 07:15 PM
scblucam's Avatar
Just to be clear, it turns over but does not fire?
68 302 M20 - 85 IROC Z
scblucam is offline
post #10 of 10 (permalink) Old Dec 1st, 14, 07:25 PM
VATS is working if engine cranks.
On another note, a reference signal goes from dist to ECM and ECM splits signal to coil for spark and to injectors for opening - you might feel a 'click' on the injector during cranking.
Ensure fuel getting to engine by looking at a spark plug.
If wet with fuel, injectors are working. Dry out plugs overnight.
Use timing light to 'see' spark.
Unplug bypass to set initial spark timing, 6 BTDC, I believe. Single wire connector next to ECM in pass side foot panel.
Then once initial timing set, disconnect battery power to erase fault code and connect bypass connector.
Ensure spring and block is installed on coil center so it will touch rotor.
Injectors have switched battery power to one lead, black wire I believe, and colored wire goes to ECM and ECM places a low upon colored wire to open injector, otherwise, close to battery power when not commanded to open.
