Help with qft carb - Team Camaro Tech
post #1 of 6 (permalink) Old Jul 1st, 15, 07:25 PM Thread Starter
James
Fitnessguy's Avatar
Help with qft carb
Okay here's a weird one. Had my carb off the car as it developed a bit of a stumble off idle a couple weeks ago. Fine at speed and wouldn't stumble every time. So pulled the carb apart, cleaned everything thinking maybe was some debris issue. Put the carb on the car today and had the wife whirl it over till I saw the bowls fill up and the primary bowls fills up past the site window! Secondary bowl fills up to middle as always. I did nothing with the float levels when I had it apart so thought okay, needle and seat got stuck. No big deal. Pulled the primary bowl off and looked at the needle and it moved no issue. Pulled the needle anyway to make sure nothing was in there which there wasn't. Set the float level a little lower than I normally had it, put all back together. Whirled over again and the damn thing filled the bowl all the way again! Have a fuel pressure gauge on it and it isn't showing higher than 6lbs which is where it usually is. So what am I missing? I have had the carb apart before and no it well. Other than pull apart to clean, I changed nothing. Stumped
Fitnessguy is offline
post #2 of 6 (permalink) Old Jul 1st, 15, 07:55 PM
scblucam's Avatar
Re: Help with qft carb
Float leaking and sinking because of filling with gas?
68 302 M20 - 85 IROC Z
scblucam is offline
post #3 of 6 (permalink) Old Jul 1st, 15, 08:08 PM Thread Starter
James
Fitnessguy's Avatar
The float looking through the site window is sitting "closed" from what I can see and like I said it isn't showing high pressure. I can get the motor to start if I hold the throttle open a fair bit but as soon as I let the throttle back down it dies obviously because it's flooding.
post #4 of 6 (permalink) Old Jul 1st, 15, 08:50 PM
You could try swapping the primary and secondary floats and/or needles & seats with each other to see if the problem moves with the parts when swapped, might help determine what is going on.
NH69Z28RS is offline
post #5 of 6 (permalink) Old Jul 2nd, 15, 05:25 AM Thread Starter
James
Fitnessguy's Avatar
So I pulled the primary bowl off again, replaced the needle and seat as I have a rebuild kit on hand. Reset the float even a little lower and put it all back together. Whirled the car over to fill the bowl again and problem solved. Put the old needle/seat beside the new one I put in and they are identical. Both move the same, there isn't a mark or anything on the old one. Don't get it. Oh well at least the problem is solved but not sure how that issue sprung up. Wanted to share the solution.
post #6 of 6 (permalink) Old Jul 2nd, 15, 08:29 PM
Morgan
Now make sure you throw that needle abs seat in the trash so you don't use it down the road
69 Copo 9560 ZL-1 automatic [email protected], 1.95 on f70-14 polyglas F.AS.T. Race June 2016
69 Copo 9560 ZL-1 4spd [email protected] 1.93 60ft on F70/14
PSMCDR 2014
71LS6 vette [email protected] PSMCDR 2012 SOLD
1971ls6 is offline
