hello - Team Camaro Tech
post #1 of 5 (permalink) Old Jan 16th, 16, 07:08 PM Thread Starter
buddy
hello
Hello thanks for letting me join i am buddy from North Carolina i am a firefighter i am trying to fix up an 1996 Z 28 with an LT1 engine i just bought the car not to long ago i have had it running but not for long i have replaced the fuel pump the opti spark crank position sensor and the battery i have fixed all the codes i was getting but the car will not idle it bucks and jumps when you try to start it and when it does you have to keep the throttle very high when you let off it will die evertime so any help i can get would be great
Thank You:
buddy tweed is offline
post #2 of 5 (permalink) Old Jan 17th, 16, 06:52 AM
Re: hello
Welcome to TC. I ran out of breath reading that, therefore I can't help cause I'm passing out. Please try using periods.
COPO is offline
post #3 of 5 (permalink) Old Jan 17th, 16, 06:58 AM
kevin
Re: hello
even the space bar would help
flat tire is offline
post #4 of 5 (permalink) Old Jan 18th, 16, 09:29 PM
PA Camaro Guy's Avatar
Re: hello
I don't have advice on this particular generation, but do welcome members wth constructive thoughts to respond to this fellow.
1969 Camaro 383
2.02/1.63 & 234/244 Vortec
TH350 / 12 bolt 3.73
PA Camaro Guy is offline
post #5 of 5 (permalink) Old Jan 19th, 16, 08:17 AM
Russ
rafbody's Avatar
Re: hello
You say you fixed all the codes you were getting, what codes were present? Have you checked the coil, spark plugs, and injectors?
Russ
'67 4 speed coupe
'67 rs coupe
'94 6 speed z-28
rafbody is offline
