Camaro dies after WOT run - Team Camaro Tech
post #1 of 22 (permalink) Old Feb 9th, 16, 05:15 AM Thread Starter
Rich
Hey guys,
I've been having an issue with my engine stalling/dying after WOT.
It's a 350ci, 4bbl Holley 4150 with electric choke and vacuum secondaries, 305 heads, stock cam, HEI ignition.
It runs fine around town at cruising speeds and in passing gear, but the moment that you go into WOT, the car won't hold idle and dies.
When you go to start the car again, it seems flooded and will only turn over if you hold down the gas pedal.
My first assumption is that the car is running too rich and it is flooding out after WOT. I've also considered my float levels to be too high and was going to adjust them. However, maybe I'm missing something.
Thoughts?
Last edited by 69-Pace; Feb 9th, 16 at 03:07 PM. Reason: merged dupe posts in one thread
Aekdbrich is offline
post #2 of 22 (permalink) Old Feb 9th, 16, 06:12 AM
George
Gbauer's Avatar
Re: Camaro dies after WOT run
Sounds like you're looking in the right places. Also check the vacuum advance to make sure it moves and your timing. Could also be a vacuum leak (mine did that when I had a big one...).
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #3 of 22 (permalink) Old Feb 9th, 16, 06:20 AM
Re: Engine dies after WOT
I was going to guess the other way, float level too low or float getting stuck. Or float getting hung up when fuel transfers/sloshes back due to acceleration.
If too low, romping on it is using all fuel in bowl, then when letting off starves the motor, then dies, fuel rushes back in an floods it.
Maybe, weak or failing fuel pump?
Does the motor die during acceleration or after let off? Does it seem to starve for fuel then die?
Does it do it whether the motor is hot or cold?
1968 Camaro SS 396 M20 Posi
PhantomRider is offline
post #4 of 22 (permalink) Old Feb 9th, 16, 06:23 AM
George
Gbauer's Avatar
I had that problem.
That's what caused it for me.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #5 of 22 (permalink) Old Feb 9th, 16, 06:27 AM
You created two threads on this topic?
post #6 of 22 (permalink) Old Feb 9th, 16, 06:46 AM
George
Gbauer's Avatar
Must be a super-serious problem.
...with his browser.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #7 of 22 (permalink) Old Feb 9th, 16, 07:17 AM
Vega$69's Avatar
Merged the 2 threads
Vega$69 is offline
post #8 of 22 (permalink) Old Feb 9th, 16, 07:25 AM
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #9 of 22 (permalink) Old Feb 9th, 16, 08:34 AM
Wire your choke to stay open and see if the problem is with your choke flap closing when your at WOT.
COPO is offline
post #10 of 22 (permalink) Old Feb 9th, 16, 11:21 AM Thread Starter
Rich
Thanks for the input guys. The motor runs fine until you come off the pedal. Once you let off, even if it's slowly, the motor will stall and shut off. But if you stay on the throttle, it still runs.
This is typically when the motor is already warm. I haven't tried it on a cold motor.
I don't think it's starved of fuel, but it's something to look at. And great thought on the advance. I'll have to check that, because it runs fine around town at cruising speeds.
post #11 of 22 (permalink) Old Feb 9th, 16, 02:39 PM
Confirm/adjust your float level first. secondly, it would be good to know what fuel pressure your pump is putting out and you can check that with a combination vac/fuel pressure gauge if you have one.
Melrose RS is offline
post #12 of 22 (permalink) Old Feb 9th, 16, 02:53 PM
Joe
If it hasn't been done in awhile rebuild your carb..
67 RS/SS 350 4sp.
Silvrmax04 is offline
post #13 of 22 (permalink) Old Feb 9th, 16, 06:58 PM
Disconnect the secondaries and retest.
If it does the same, plug the secondary bowl vent.
If still does it, lower fuel level in secondary bowl to off, and remove lower bowl screw to drain fuel and retest.
If it improves, reset float lower and/or install a vent cover on secondary bowl vent inside on the plate. Do the same to primary side as vents come in pairs.
post #14 of 22 (permalink) Old Feb 10th, 16, 07:20 AM Thread Starter
Rich
Ok. Primary float is spot on. No adjustment needed. My secondary float was WAY HIGH. I lowered the secondary float level and now I can't get the damn car to start?!
One, with that float being so high, could that cause the issue at WOT?
And two, if I can't get the car to start, would a LOW float level in the secondary cause that? I'm definitely getting spark, but I will also be changing the spark plugs because of carbon buildup.
post #15 of 22 (permalink) Old Feb 10th, 16, 07:21 AM Thread Starter
Rich
I feel a little dumb, but I haven't had a lot of experience with fuel systems.
It is what it is. Haha.
