1994 CAMARO security light - Team Camaro Tech
post #1 of 2 (permalink) Old Oct 8th, 16, 10:51 AM Thread Starter
dan
Question 1994 CAMARO security light
i have a 1994 camaro that key was replaced on with normal key runs fine but security light is on very annoying how do i shut off light ??
dammdan311 is offline
post #2 of 2 (permalink) Old Oct 8th, 16, 11:12 AM
69-Pace's Avatar
Re: 1994 CAMARO security light
The key with the chip disables the light, without it you will see it as a reminder that the key in the ignition is not "real" The VATS system was designed not to start with a non "real" key in the ignition so consider yourself lucky. You can bypass VATS security using homemade boxes. Google it.
Here is one from the ls forum http://ls1tech.com/forums/conversion...ypass-box.html
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
