Powerglide Pops out of drive - Team Camaro Tech
post #1 of 3 (permalink) Old Oct 14th, 16, 07:53 PM Thread Starter
chuck
I have a '68 Camaro drop top with a powerglide trans. I had it rebuilt w/a 2500 stall converter. Under load in
drive from a stop the trans pops into neuteral and the engine revs. What's up with my trans?
bubba123 is offline
post #2 of 3 (permalink) Old Oct 14th, 16, 08:48 PM
Re: Powerglide Pops out of drive
Might pay you to pull the pan and look at the shift detents in the valve body or any of the outside linkage that may not be aligned correctly . PG trans are pretty simple to work on.
TC # 349
zdld17 is offline
post #3 of 3 (permalink) Old Oct 21st, 16, 07:38 PM
Nick
check the engine and tranny mounts
67 rs/ss 350 original eng,700r4, a/c, tilt, deluxe int,strato bench,Ca.emission,front disk,am/fm,floor clock,17" W/V Ralleys,Toyo T1S 255/40/17, 245/40/17
MRCOOL_RSSS350 is offline
