Hood popping open during driving - Team Camaro Tech
 1Likes
  • 1 Post By KevinW
post #1 of 4 (permalink) Old Jun 14th, 17, 12:17 AM Thread Starter
Jake
I am having an issue with my 69 camaro hood popping open during driving. It doesn't come flying open, just pops up and I'm guessing catches the latch. I couldn't find any threads about this. Do I just need to lower the hood adjusters? It doesn't do it every time I have the car out, but appears to do it under hard acceleration. Any ideas?
1969 camaro with lq9/4l60e trans (3800 stall), hotchkis suspension, kor3 c6 brakes, boyd coddington pt-22 18in wheels
sscamarokid is offline
post #2 of 4 (permalink) Old Jun 14th, 17, 04:59 AM
Kevin
KevinW's Avatar
Re: Hood popping open during driving
If the hood sits flush where it is supposed to, then you need to adjust the striker pin on center of the the hood. It is likely the latch is not closing all the way on the striker. 1st with hood closed, look up from underneath with a strong light. Is the head of the pin fully underneath latch? if not, you can adjust pin downwards with a large screwdriver counter clockwise. Also if latch is not lubed, this might cause latch to not fully seat the pin. Luck!
pittpens24 likes this.
Kevin
KevinW is offline
post #3 of 4 (permalink) Old Jun 14th, 17, 05:42 AM
Greg
pittpens24's Avatar
X2 on what Kevin said and something that I used to do in the past was to run a cable through the latch and lock it down for both added security and to keep the hood from flying open incase of latch failure.
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is offline
post #4 of 4 (permalink) Old Jun 14th, 17, 04:31 PM
Fred
77thor's Avatar
I had the same problem on my 69... To fix it;
I loosened the 4 bolts holding the metal plate(with the striker pin) to the hood, there is some play in it, and moved it slightly then tightened it down again.
Then I went for a drive over a bumpy road to test it.... It took a few tries but eventually it did fix the problem.
77thor is offline
