Well, that didn't work!!!! - Team Camaro Tech
 2Likes
  • 2 Post By rtchaney
post #1 of 6 (permalink) Old Apr 15th, 18, 09:40 PM Thread Starter
Robert
rtchaney's Avatar
Ok, So I have followed the attached diagram to get my Vintage Air compressor signal to trigger a series of relays to turn on a secondary electric fan and use the Holley Sniper A/C Ground sensor to bump my RPM by 100. It didn't work. lol! the only thing I did different was that I ran Pin-87 on the middle bottom relay directly to my compressor. I didn't plan on using the A/C RPM Shutoff function.
Any Ideas? I'm at a loss....
1968, 5 speed, Vintage Air Gen IV, American Auto Wire Update Series, Champion 4 Core Rad, BMR front w/ Koni's, BP Roller 383, Posi 8.2", Solid Frame Bushings
rtchaney is offline
post #2 of 6 (permalink) Old Apr 16th, 18, 06:11 AM
Re: Well, that didn't work!!!!
I think the relay schematic is wrong. Generally, a de-energized relay will have continuity through 30 to 87, not 87a. Check?
Present relay, upper right corner, is shown in energized position. So, everything you're trying to 'turn on', should be wired to 87a.
Doing a good job is like peeing in your dark pants Ö you get a warm feeling, but nobody notices
post #3 of 6 (permalink) Old Apr 16th, 18, 10:51 AM Thread Starter
Robert
rtchaney's Avatar
Lol! I thought 87a was normally closed?
rtchaney is offline
post #4 of 6 (permalink) Old Apr 16th, 18, 01:04 PM
Rick
Correct. 87 is normally open until energized by 85,86
69 COPO clone, 461" BBC 11.25:1 Compression
840 Rec Heads (2.25/1.88) AED 850 HO carb
Orig Exhaust Manifolds
Straub (Clay Smith) cam, 288/300 .600/.569 109.
TH400, 3500 stall, 4.11 12 bolt posi
rp930 is offline
post #5 of 6 (permalink) Old Apr 17th, 18, 06:13 AM Thread Starter
Robert
rtchaney's Avatar
Fixed it! I had the compressor wire and the a/c switch wire swapped. Sometimes a fresh look and sleeping helps. Thank you gentlemen. At least now I can say, for certain, that the diagramed circuit is good and functions propperly; even if I don't!
Everett#2390 and 130fe like this.
rtchaney is offline
post #6 of 6 (permalink) Old Apr 17th, 18, 07:20 AM
Very good
