cant see videos posted here - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 29th, 18, 05:38 AM Thread Starter
kevin
I cant see any videos posted on this site. not even the one I posted about using a towel to remove a window handle .
I can post the same video else where and I cant see it
ideas?????
for the heck of it I switched to the FULL version and I could see them. just not on the classic version
flat tire is offline
post #2 of 4 (permalink) Old Sep 29th, 18, 08:07 AM
69-Pace's Avatar
Re: cant see videos posted here
Look at your security and flash settings, and what browser, and what version is it?
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 4 (permalink) Old Sep 29th, 18, 03:20 PM Thread Starter
kevin
don't know what a flash setting is
shouldn't security be the same with both versions
IE windows 7
post #4 of 4 (permalink) Old Sep 30th, 18, 11:52 AM
69-Pace's Avatar
Flash is now a "legacy" add-in and by default policy updates and browser updates have been turning it off.
IE 11 in Windows 7 recently updated policy and turned off a lot of settings.
Easy first try fix is to go to the security tab in internet options and add https://camaros.net to your "trusted sites" list. In the security tab of your internet options click Trusted sites first, then add site. Next set security for that "zone" by clicking the custom level radio button at the bottom. It most likely is set to Medium-High (default). In the pull-down select Low. Then apply and ok until internet options are closed, then restart your system then browse to our site and see it that resolved your issue.
If it did then you know the issue is security based not software. If it did not then your issue is more complicated. You should be okay running in Low security but remember all security for the sites in your trusted list has been set to the lowest. You could go back into security and look at the settings in that zone and raise the level from LOW to Medium Low, reboot and relaunch and see if you can still see the videos. If it still works try Medium next and if it still works leave it there assuming your settings started out at Medium-High (default). If your settings started higher than that keep incrementally increasing until you are one step below your starting point to be the safest on-line.
69-Pace is offline
